August 18, 2008, 08:30 |
Help required on solar modelling
I'm trying to simulate the effect of solar radiation on a metal enclosure. There is no air flow into the system. When I simulated case using the solar model, I got an info on the solar load which was 0 w/m2. The solar flux is equal to 0 w/m2 even after many iterations. The temperature within the system is less than 45 degC, which is not the same in actual condition. Can anyone help me on this problem. thanks in advance, sridhar |
August 19, 2008, 13:59 |
Re: Help required on solar modelling
Please set radiation properties. If you don't have surface properties then there will be no radiation heat transfer or absorption.... Check the model if it has these details...
Thanks, AJ |
August 20, 2008, 00:58 |
Thanks AJ, I have set the radiation properties for the surfaces as opaque, participates in solar ray tracing and absorptivity - visible - 0.78 and IR 0.91. Please correct me if I'm wrong.
Thanks, Sridhar |
Modelling a solar simulator in Fluent | Ben | FLUENT | 0 | January 16, 2008 09:43 |
solar radiation modelling | PONDA | FLUENT | 0 | April 6, 2007 03:51 |
Modelling solar distillation | Forrest | CFX | 1 | February 22, 2007 07:21 |
solar radiation | Arnold | FLUENT | 0 | May 2, 2006 21:00 |
cfd analysis of a solar car | Sandile Peta | Main CFD Forum | 0 | January 29, 2006 06:05 |
