please help,open tank problem
hi,i will be really grateful to you.
problem: my tank is open to atmosphere,1/3 filled with water.remaining is air inlet and outlet is in the botttom,which is circulating the water in the tank and maintaining constant level.it is some steady type problem.. i tried lot to solve it by VOF model cosidering two phase flow,,,..but i m not getting seperate path line for air and water......so how i should solve it.. please help me. |
Pump Sump Simulation
hey im simulating a multiphase flow in an open tank with outlet to pump suction pipe and inlet from the side of the tank. about 2/3 of tank is filled with water and the rest is air. its like a steady flow. i have a problem that my flow is not making a lot of sense with the water is jumping to the top of the tank. i set the boundary conditions with velocity inlet in the side, pressure outlet at the pump suction, and pressure outlet at the top with atmospheric pressure. please, anyone, i need your help.
