-   -   calculation of heat transfer with defined Humidity (http://www.cfd-online.com/Forums/fluent/49062-calculation-heat-transfer-defined-humidity.html)
dev.... August 21, 2008 03:10
Hi all
I want to get temperature distribution on flat plate having some definite temperature. I have an enviornment of CO2 aourn the flat plate with Relative humidity of 70% . Temperature of flat plate is less than the enviornmental temparature (let say temp difference is 10 deg Centigrade). Can any body tell me, 1. which model i should choose for analysis in fluent. 2. what BC i must apply.
yours suggestions would be appreciable & thanks in advance if any body can help regard same.
