How to run the analysis from the ICEM-CFD mesh? |
August 22, 2008, 02:28 |
How to run the analysis for ICEM-CFD meshing file using fluent 6.3??
If the geometry is too complex and not able to mesh (always error) in the gambit...then...any suggestion??? Pls...help me... |
August 22, 2008, 12:35 |
Re: How to run the analysis from the ICEM-CFD mesh
In ICEM-CFD, after creating your mesh go to the rightmost tab. Click the first button in this tab to set the solver. Make sure to save your project and then click the 4th button to export the mesh to fluent.
Also, try making the boundary (surface) mesh with gambit and then use tgrid to make the volume mesh.
August 22, 2008, 20:52 |
Will, thank you for your response i will try it...
Local mesh control in ICEM (for hex mesh) | Debabrata Mahapatra | CFX | 1 | October 17, 2007 10:45 |
Airfoil Mesh for DES Analysis - y+ Value | asd | Main CFD Forum | 1 | May 3, 2007 10:13 |
Dynamic mesh analysis | Hussein | FLUENT | 0 | February 19, 2007 08:03 |
2D Mesh Generation and Analysis | Deepthi | CFX | 2 | February 27, 2004 14:05 |
Is Mesh Accessary for Analysis | Selina Tracy | Main CFD Forum | 2 | March 24, 2001 22:23 |
