unsteady statistics in UDM
Like Tree1Likes
  • 1 Post By max
Old   August 26, 2008, 10:20
Default unsteady statistics in UDM
A. Dehbi
Hello all,
Using Fluent LES/DES models, there are all sorts of statistics available in the Contour/Plot menus (e.g. rms of velocities). I want to use these in a UDF but there does not seem to be a macro for that. Is there a way I can store these rms values in a UDM to be available later for a UDF? Any clue will be appreciate.
Best,
A. Dehbi
Old   August 27, 2008, 04:33
Default Re: unsteady statistics in UDM
max
Hello A. Debhi,
login to the Online Technical Support and have a look at solution 1210. It gives you a hint how to obtain unsteady statistics within a udf.
cheers Max
xiaoyefeiyang likes this.
Old   August 27, 2008, 06:12
A. Dehbi
Hi Max,
Great pointer! Works fine. Thanks so much!
Abdel
Macros for unsteady statistics Abdel Dehbi FLUENT 0 August 30, 2008 10:31
unsteady statistics for UDF Luis FLUENT 0 April 16, 2008 15:45
Unsteady Statistics- incorrect calculation, etc. John FLUENT 0 June 27, 2007 19:04
unsteady statistics shefali FLUENT 0 August 12, 2006 20:13
mean boundary values for unsteady statistics Francois FLUENT 0 March 21, 2005 10:28
