Home > Forums > FLUENT
DEFINE_SOURCE error
Old   August 28, 2008, 10:13
Default DEFINE_SOURCE error
romans
Hello, I am solving the diffusion equation with the concentration formulation. I would like to add a source term via UDF that includes the gradient of concentration but I get an Access Violation error when I try to use the C_UDSI_G(c,t,i) macro. Can I use this macro with the concentration formulation?
my code is:
DEFINE_SOURCE(MySource,c,t,dS,eqn)
{ real Rw,Dc,De,Q; #define Rw 4.0e-4 #define Dc 0.0001 #define De 4.0e-5 #define Q 2.14e10
real x[ND_ND],XX, Source;
C_CENTROID(x,c,t);
XX=De*C_UDSI_G(c,t,C0)[2];
Source=XX-(Rw+Dc)*C_UDSI(c,t,C0)+Q;
C_UDSI(c,t,C1)=C_UDSI_G(c,t,C0)[2];
dS[eqn]=XX*C_UDSI_G(c,t,C1)[2]-Rw-Dc;
return Source; }
I have used the first derivative and second derivative.
Best Regards, thank you
romans
Old   August 28, 2008, 22:09
Default Re: DEFINE_SOURCE error
romans
HI, I have used the first derivative and second derivative for the user defined scalars,when i initialize source terms, i get this error,just like: error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: ()
would you help me? Thank you in advance.
romans
Old   August 29, 2008, 00:34
CDE
in the C_UDSI_G(c,t,i) macro, you use i = C0. Is C0 an integer?
Old   August 29, 2008, 05:57
romans
Hi, in the C_UDSI_G(c,t,C0) macro, C0 is an integer. the code is compiled without error. now, i want to get the second derivative for C_UDSI_G(x,t,i),how to do?
Thanks.
romans
Old   April 30, 2012, 22:08
Pacheo
pacheo is on a distinguished road
Originally Posted by romans
;153064
Thanks.
romans
try to calculate several steps, then hook your udf.
hope that can help you.
pacheo is offline   Reply With Quote
Old   May 1, 2012, 20:00
Krishna
t.krishnamohan is on a distinguished road
The last argument in the DEFINE_SOURCE is an index. In your case it is eqn. C0 and C1 are not defined in your code.
t.krishnamohan is offline   Reply With Quote
Thread Tools
Trackbacks are On
DEFINE_SOURCE PK FLUENT 0 December 6, 2006 11:36
DEFINE_SOURCE CN FLUENT 2 August 5, 2005 11:29
DEFINE_SOURCE saghir FLUENT 0 May 12, 2005 03:53
DEFINE_SOURCE Dolores FLUENT 2 May 18, 2004 05:18
error message about using DEFINE_SOURCE emma FLUENT 5 April 2, 2004 04:18
