August 30, 2008, 00:12 |
reynolds number flow
Dear all
I ran a large eddy simulation of a flow over a urban terrain. After an initial run I checked the results of flow over certain points and found it to be reasonable. I then doubled the viscosity and the inlet velocity. I reran the simulation, then found the flow pattern was similar, as would be expected with the same reynolds number. However the velocities are slightly different at the points. Is this a reasonable result ? Also should the sgs viscosity be doubled also. I assume not since the viscosity of the SGS model is based on the strain rate and has already been changed since the inlet velocity has been changed thanks richard |
Low Reynolds Number Flow over a Flat Plate | Go | FLUENT | 4 | August 28, 2013 05:19 |
Turbulence model for low Reynolds number flow? | Nokadu | Main CFD Forum | 3 | May 26, 2013 11:42 |
Low Reynolds number flow | Terje | CFX | 3 | June 20, 2007 08:10 |
Free Flow Reynolds Number | bharath | Main CFD Forum | 0 | November 21, 2002 15:37 |
Low Reynolds Number Flow Computation | A.M.Yang | Main CFD Forum | 7 | January 22, 2002 12:01 |
