UDF Compile Error
Old   September 4, 2008, 11:55
Default UDF Compile Error
Zach
I am using parrallel fluent on a windows maching with two processors. When I build my udf library I get a 'nmake' is not recognized as an internal or external command, operable program or batch file error. Then, when I load the library I get another error that says Error: open_udf_library: The system cannot find the file specified. Any ideas?
Thanks,
Zach
Old   September 4, 2008, 22:15
Default Re: UDF Compile Error
Daniel Tanner
Fluent cannot find your system compilers. You need to have a C compiler to use the compiled udf function. If it is a basic udf, interpreted udf might work.
Good luck.
Old   September 5, 2008, 03:28
Zach
I do already have a compiler installed (visual studio). Any other ideas?
Old   September 5, 2008, 04:01
doki
that may be because of the compiler type. as I have had such problems, in some cases, there seems the system rather tries to find a CPP compiler nor the visual compilers.
Old   September 6, 2008, 04:23
Fabio
Hi, i've got this kind of problem some times ago, the solution in my case was installing Visual Studio and Fluent in the same root directory, if you have already done that try changing the folder with another like \C because i think long path files are not good. I hope this helps
Old   September 11, 2008, 07:42
Daniel Tanner
There is a newer forum discussion on this which may be helpful (http://www.cfd-online.com/Forum/fluent.cgi?read=60629), I posted the following.
I had the same issue.
You need to use the "Visual Studio Command Prompt" from the start menu in windows to launch fluent. If you are using a 64-bit system use the 64-bit version not the standard i.e. for me I use "Visual studio 2008 x64 Win64 Command Prompt".
Also make sure you launch fluent from the directory containing the C files!
Hope this helps!
Old   September 20, 2008, 07:35
Madusuthanan
i also get he similar problem before, i solved this problem by downloading nmake utility from folling id http://support.microsoft.com/default...;en-us;Q132084
execute it and also keep that utility in your \windows\system 32 folder that will solve my problem.
You can try this
error msg when compile the udf brusly FLUENT 0 December 2, 2007 10:11
UDF Compile Error Quak FLUENT 3 July 20, 2005 08:31
help!udf compile error Fred FLUENT 4 June 21, 2005 00:05
UDF compile error tony FLUENT 1 May 10, 2005 05:47
Help! UDF Compile Error Michael FLUENT 1 January 18, 2002 16:24
