Mesh generation in Gambit
Old   September 8, 2008, 17:39
Default Mesh generation in Gambit
summer
Hello, I am creating a mesh for 3D pipe in Gambit. The pipe is 25.4mm ID and 2.038m long. The requirement of the mesh is as: 1. Along the azimuthal-direction: small number less than 10 2. Along the radial-direction: around 20 3. Along the axial-direction: around 1000
Is there any suggestions? I tried different ways in Gambit but failed to do it. I appreciate it if some one kindly provides any suggestions.
Old   September 9, 2008, 04:00
Default Re: Mesh generation in Gambit
twiti
That would be helpful to split the pipe if it's not a straight one.
Old   September 10, 2008, 15:24
summer
Thank you very much for the reply. Could you please provide more details? Do you mean that I use another smaller pipe to divide my pipe into two parts?
Old   September 11, 2008, 11:06
MW
What does the geometry look like? Post a screen capture. Upload it on imageshack.
Old   September 11, 2008, 15:09
summer
Thanks for the reply.
The pipe is simply straight with a diameter of 25.4 mm and 2.038 meters long. I appreciate it if any suggestions are provided.
Gambit C-Grid Generation Nick Main CFD Forum 1 August 21, 2007 12:10
???Gambit grid generation...??? Yreadj FLUENT 1 January 30, 2007 18:06
gambit mesh generation for core annular flow anand FLUENT 0 November 17, 2005 02:33
GAMBIT grid generation karthik FLUENT 4 February 12, 2005 13:28
Mesh Generation in Gambit Tariq FLUENT 1 January 5, 2005 02:19
