September 9, 2008, 12:39 |
negative RPM
Is it possible to specify a negative rpm in the multiple reference frame model. I am simulating a 3D rotor, the geometry etc is fine and when I specified a 70rpm value the flow path was very strange. I thought I had the rotation in the wrond direction so I just used -70 rpm but the results are now too low. If I have a 3D rotor with the axis of rotation around z axis and origin 0,0,0 (x, y, z), looking topdown on this is the normal positive rotation clockwise or anticlockwise? Thanks very much |
September 12, 2008, 01:47 |
Re: negative RPM
Negative rpm is acceptable in FLUENT.
Display Modes | |
Negative Pressure | Kevin | Fidelity CFD | 9 | November 4, 2019 12:08 |
Negative pressure! | Neel | CFX | 0 | March 19, 2008 08:47 |
negative vol | roy | FLUENT | 3 | April 27, 2004 10:38 |
what can cause the negative K? | Lee | Siemens | 1 | June 24, 2003 20:34 |
negative uds value despite zero bc | Elmar Riesmeier | FLUENT | 3 | June 11, 2001 22:22 |
