Modifying a mesh starting from case file
Hi to all,
I have a case file (no original msh or dbs), and I would like to export the grid to Gambit or ICEM-CFD format to modify the mesh, and then set up a new simulation. What's the best way to do that? Thanks a lot in advance, Ale |
Re: Modifying a mesh starting from case file
ICEM CFD can load the .cas file directly (File > Mesh > Import Mesh). From that you can do Edit > Mesh to Facets to extract a geometry - then re-mesh.
Thanks a lot!
