About the multiphase flow
Hallo,
I am puzzled about the multiphase flow. Does the multiphase model can be used in steady flow? I tried to simulate a case with the mixture model or Eular model for the system air and water (the case looks like the bubble flow), I would like to see how much air are mixtured into the water when it comes to the steady state. Therefore, I treated it as a steady flow. However, there is always a error information below and the simulation can not go on in 100 iterations: turbulent viscosity limited to viscosity ratio of 1e5. However, if I changed it into unsteady state, the information above only exists in several time steps and disappear after a short time. Does somebody can tell me, whatis the reason for that? Does it mean that the multiphase model can not be simulated in steady state? thanks a lot xue |
Re: About the multiphase flow
Is there anybody who can give me some suggestions?
Thank you very much! xue |
Have you tried transient to see if you can run your model? Normally large density differences can not be run steady state. So run transient and after you reach a quasi-steady flow you can turn the time-averaging feature in fluent and look at the time average results.
Hi, Bashu,
Thank you very much for your kindly reply. I have tried, it can work in transient. Could you tell me the reason that we can not run it in steady state for the large density differences system? Thanks again! xue |
Just to make it clear it is not just the density difference that's important. You have the volume fraction effect as well. In other words for a dilute system (<2%) you should be able to have a steady flow regardless of density difference. The multiphase is normally transient since the time scales of the two phases are much different and so they won't flow together.
