September 19, 2008, 20:16 |
reference values for two in line cylinders
Hey,
i'm modelling flow past two parallel cylinder with different diameters and i'm unsure on what to set as the reference values for area and length, the model is 2D. For the single cylinder model i used the diameter which i believe to be correct. Please can somebody help me? |
September 20, 2008, 08:34 |
Re: reference values for two in line cylinders
not that important! it does not effect the solution. get the solution, just set as to one of geometries, and then get necessary results (e.g. drag and drag coefficient) and then change it to another geometry and do the same! good luck
REFERENCE VALUES | Ojo | FLUENT | 4 | December 5, 2019 15:29 |
Reference Values- Reference Area | Shivakanth | FLUENT | 12 | June 6, 2017 00:18 |
reference values | evans | FLUENT | 1 | January 29, 2008 06:22 |
Reference Values Help | Sham | FLUENT | 0 | February 26, 2005 08:43 |
porous media - C1 C2 values for cylinders | Ralf Schmidt | FLUENT | 6 | November 18, 2004 06:35 |
