-   FLUENT (
-   -   parallalizing GAMBIT (
tamjid September 21, 2008 02:30
HI FELLOWS, i am facing out of memory problem during ghambit 3d meshing. i have core 2 duo ,2.5 GB ram m/c.
can gambit be run paralla as fluent. or is there any other idea.
please share.
thank you.
red lemon September 21, 2008 17:35
Re: parallalizing GAMBIT
Gambit does not run in parallel. Try using a 64 bit machine and breaking up the model into more sub volumes. Otherwise use 64bit TGrid instead.
tamjid September 25, 2008 03:59
how do you use 64-bit TGrid? explain a little bit.
thank you.
Ganapathy September 25, 2008 07:45
Gambit is available only as a 32 bit version. TGrid is available in two versions. 32 bit as well as 64 bit. You need to download a 64 bit version of TGrid from You also need a 64 bit machine.
tamjid September 30, 2008 10:49
i will try.
