URANS - how to get going?
Like Tree1Likes
  • 1 Post By Hossam
Old   September 26, 2008, 11:32
Default URANS - how to get going?
Carlos
Does anybody know how to carry out URANS simulations? Is it just a case of picking your RANS turbulence model then selecting the unsteady formulation? The Fluent manual is useless in this regard.
Then I assume you carry out timestep size changes until you get a good solution? Hope you can help...
Regards,
Carlos.
Old   October 2, 2008, 19:57
Default Re: URANS - how to get going?
Hossam
yes you are right, you pick a RANS model and use the unsteady solver. however, care must be tafen when adjusting the time step size. the time step should be larger than the turbulence scales turn over time and also small enough to capture the unsteady behaviour of the mean flow. this to ensure that the turbulence eddies are modeled and the unsteady behaviour of the mean flow is resolved. you should check the corresponding literature to make the appropriate choice of this time step
pinkerthoms likes this.
Old   October 3, 2008, 08:24
Carlos
Thats great, many thanks!
RANS and URANS. prasat Main CFD Forum 17 November 15, 2022 14:30
URANS Magic Main CFD Forum 3 November 30, 2006 10:10
URANS: questions FELIPE Main CFD Forum 9 April 29, 2005 13:08
URANS / RANS??? FELIPE Main CFD Forum 0 April 1, 2005 21:10
URANS and PHANS ?? gorka Main CFD Forum 0 November 11, 2002 08:12
