September 29, 2008, 06:03 |
Looping in Journals error
I am doing some 2d simulation of wings, and I am trying to write a journal file that will allow me to automate solving for a set of angles.
However, in the following section of code I get the error Error: eval: unbound variable Error Object: /define/boundary-conditions/velocity-inlet The relevant code is here, if it is not too much trouble to check it... (define ang 0) (define angmin -5) (define angmax 5) (define angstep 5) (define window 1) (define save "ggsf_naca4102_at") (define degtorad 0.0174532925) ------------{here is a long section that sets up the solver and runs one simulation and saves the data, I don't think there are errors here}----------- (set! ang angmin) (let tiltup ((ang angmin)) (if (> ang angmax) (display "DDDOOONNNEEE") (begin (define angstr "-5") (define angrad (* ang degtorad)) (define savefile (string-append save "at" angstr "deg" "030" "ms")) (define savefiledat (string-append savefile ".dat")) (define ycomp (sin angrad)) (define xcomp (cos angrad)) /define/boundary-conditions/velocity-inlet 6 yes yes no 30 no xcomp no ycomp yes no 0.001 /solve/monitors/force/clear-all-monitors-data yes yes yes /solve/monitors/force/lift-coefficient yes 4 () yes no yes 2 no ycomp xcomp /solve/monitors/force/drag-coefficient yes 4 () yes no yes 1 no xcomp ycomp /solve/initialize/compute-defaults/velocity-inlet 6 /solve/initialize/initialize-flow /solve/iterate 200 10 1 (cx-gui-do cx-activate-item "MenuBar*WriteSubMenu*Data...") (cx-gui-do cx-set-text-entry "Select File*Text" savefiledat) (cx-gui-do cx-activate-item "Select File*OK") (tiltup (+ ang angstep))))) ;end angle loop Thanks for any help! (Sorry about the empty lines, but I can't figure out how to add line breaks) |
September 30, 2008, 09:06 |
Re: Looping in Journals error
Nevermind the problem, I found out that I have to use (ti-menu-load-string "blabla")
Now I am getting the error: Error: CAR: invalid argument [1]: wrong type [not a pair] Error Object: () Somewhere in the following lines of code: (ti-menu-load-string (format #f "/define/boundary-conditions/velocity-inlet 6 yes yes no 30 no ~a no ~a yes no 0.001" xcomp ycomp)) (newline) (ti-menu-load-string (format #f "/solve/monitors/force/clear-all-monitors-data yes yes yes")) (newline) I have a suspicion that it might be due to a different syntax in fluent 6.3, as that line was from an older tutorial. |
September 30, 2008, 10:03 |
Correction: the error is in this line (atleast it turns up when this one is added):
(ti-menu-load-string (format #f "/solve/monitors/force/lift-coefficient yes 4 () yes no yes 2 no ~a ~a ") ycomp xcomp)(newline) Many thanks, Kai |
October 2, 2008, 09:23 |
Fixed. Now how to return a default value?
I found my error, miscounted prompts somewhere :P.
How do I script the default value to be returned for a prompt? Kai |
Display Modes | |
Qns abt AIAA journals submission | KK | Main CFD Forum | 3 | December 1, 2008 08:33 |
about journals ranking | John | Main CFD Forum | 6 | September 17, 2007 16:26 |
Looping over nodes of a cell (UDF) error | Manoj | FLUENT | 2 | December 1, 2005 01:30 |
American journals | R | Main CFD Forum | 0 | November 6, 2004 07:17 |
CFD Journals | Andy | FLUENT | 1 | August 28, 2002 14:26 |
