Home > Forums > FLUENT
Suggestion- regarding devergence x- momentum
Old   September 29, 2008, 09:39
Default Suggestion- regarding devergence x- momentum
Ramesh.K
Hi all,
I have the following problem I am trying to simulate the flow on square block using k-epsilon turbuelnce model
I have inlet velocity to be 1.5m/s so that with the turbulent intensity at inlet to be 0.5% and the hydraulic dia 0.2 m
its a 2d case where in I am gettting the following error
Divergence detected in amg solver x-momentum after few iterations
time step I have given is 0.00066
any suggestions
and one more question regarding gambit meshing immediately after grid check in fluent says that grid has high aspect ratio and asks us to turn on the high aspect ration computation using text mode? any Idea regarding this
thanks
Old   September 29, 2008, 10:27
Default Re: Suggestion- regarding devergence x- momentum
jay
hi
mesh is the problem..check the skewness of mesh..if it is more than 0.97, divergence may occur.
remesh it again..and try
Old   September 30, 2008, 00:52
Prasad
As Jay points out, inadequate mesh resolution may be the reason. Please try doubling the number of cells.
Thread Tools
Trackbacks are On
need suggestion Kishore FLUENT 2 September 27, 2006 16:49
need some suggestion nabeel FLUENT 4 June 27, 2006 00:36
need some suggestion nabeel mohsin FLUENT 7 August 23, 2005 04:45
Who is Who in CFD? - A suggestion. ma Main CFD Forum 2 June 16, 2004 16:41
Suggestion please newbie FLUENT 0 October 29, 2001 22:28
