October 7, 2008, 03:29 |
hwo to import a *.neu file to gambit?
hi !
i had mported a *.neu file to gambit ?there is a error"the gambit file header (record1) is non-standard".somebody can tell me the reason? |
October 7, 2008, 07:49 |
Re: hwo to import a *.neu file to gambit?
yes pleae see format of neu file in gambit tutorial, then incorporate these change
October 7, 2008, 20:53 |
yes!i see format of neu file in gambit tutorial,and use the example of the tutorial,there are many errors.
why? |
October 8, 2008, 09:21 |
According to my knowledge, this file has a fixed format, you must write your files according to *.neu files's fixed format. Please check your file.
October 8, 2008, 21:24 |
thanks you !but my *.neu file was the example of gambit user's guide.
how can i import igs file in gambit? | Javier | FLUENT | 2 | May 23, 2011 10:51 |
STL file import to GAMBIT | Spyros Stamatelos | FLUENT | 3 | January 11, 2007 12:20 |
Import gambit file in Tgrid | Elizabeth | FLUENT | 2 | December 1, 2005 10:30 |
How to import PARTRAN file to Gambit?! | anisa | FLUENT | 4 | June 7, 2005 04:24 |
Import IGS file into gambit | Burley | FLUENT | 2 | July 11, 2000 17:41 |
