October 7, 2008, 20:57 |
can i set boundary condition in fluent?
if i did not set the boundary condition in gambit ,can i set the boundary condition in fluent?how do that?
October 8, 2008, 03:25 |
Re: can i set boundary condition in fluent?
Hi, As u said, yes you can define BC in fluent. If you do not define BC in Gambit, by DEFAULT it takes as WALL BC to each of the edges (for 2-D problem) or faces (for 3-D problem. you go to Define BC in Fluent, choose that FACE/EDGE (left panel)& on the Right side pannel you option of BC. if you want to define Vel Inlet, just click on Vel Inlet. 1 msg window will ask you to change BC. You choose YES. then you will get your desired BC on that EDGE/FACE.
October 8, 2008, 10:09 |
thanks you very much!you did not understand my problem. i mean add boundary condition not modify boundary condition ?anyone can help me?
October 9, 2008, 03:15 |
If yoy dont set any bc in gambit, then gambit will set a default wall bc for every face. But you can change them later in fluent, like dev said...
cheers |
fluent boundary condition | umesh kumar jha | FLUENT | 0 | June 26, 2008 02:43 |
Fluent boundary condition | jay | Main CFD Forum | 1 | March 5, 2007 10:50 |
How to set boundary condition in Fluent for the fo | Peiyong | FLUENT | 1 | November 10, 2006 11:44 |
Boundary Condition for Fluent 4. | Sanjib Das Sharma | FLUENT | 1 | September 13, 2001 12:34 |
MHD boundary condition with FLUENT | Damien | Main CFD Forum | 0 | May 28, 2001 08:13 |
