-   -   Meshing Problem (http://www.cfd-online.com/Forums/fluent/49501-meshing-problem.html)
Abi October 14, 2008 02:28
Meshing Problem
Hi Dudes,
I have an 2d rectangular model, in which i have splitted it into 3 regions, I have to mesh the three regions separately with different mesh size. So whether i have to use interface in between these regions. Pls give me ur suggestions.
With regards. Abi
Rishikesh October 14, 2008 05:31
Re: Meshing Problem
yeah u hv to use interface.coz the common edge in the 3 regions will hv the same interval size which will prevent u from using different interval sizes.
Abi October 14, 2008 06:02
Re: Meshing Problem
Hi rishikesh,
Pls can u explain me in detail, because i am not getting ur answer. Thanks for ur reply.
With regards, Abi
Rishikesh October 14, 2008 06:06
Re: Meshing Problem
abi jus try meshing ur geometry without using interfaces.
u will understand what i told u.
Rishikesh
Abi October 14, 2008 06:22
Re: Meshing Problem
Thanks again rishikesh, then in what case we have to use interface can u tell me pls......
Regards, abi.
Rishikesh October 14, 2008 06:27
Re: Meshing Problem
interface is used when u want different interval sizes in the same geometry and an edge or face is common to 1 or more parts that u r meshing.
if u hv any further doubt,feel free to contact me.
Rishikesh
Abi October 14, 2008 06:40
Re: Meshing Problem
Hey rishikesh thanks a lot for ur quick reply, co operation and co ordination. Since I am using different mesh size in that three regions, so why can't I use that.
With regards, Abi
Rishikesh October 14, 2008 06:59
Re: Meshing Problem
u cannot give different interval sizes to the same face/edge.
at least my experience tells me this.
i am also not vastly experienced in cfd,but whatever of gambit i hv used i think this is the case.
rishikesh
Abi October 14, 2008 07:04
Re: Meshing Problem
Ok thanks for spending some time for me, let me know if i have some problem.
