Pressure build-up with VOF in a closed domain |
October 16, 2008, 03:26 |
Dear all,
I have problems trying to reproduce in FLUENT a pressure build-up phenomena due to external heat flux applied on the walls of a closed domain with two phases (liquid and gas)inside. The procedure recommented in FLUENT is the Floating Operating Pressure option. This works for a no-multiphase model and the solution is quite closed to the thermodinamic theory. But it doesn't for the multiphase: the pressurization rate is 50% more than expected. Did anybody face before this kind of problem? Thanks a lot. Best regards, Juan |
PLEASE, HELP: INTERPOLATION + CLOSED DOMAIN | Sasha | FLUENT | 4 | May 27, 2008 23:08 |
help:pumping gas into a closed domain | frank | FLUENT | 4 | April 11, 2006 09:27 |
pressure distribution in closed enclosure | Prasanth | FLUENT | 2 | February 18, 2004 05:36 |
pressure distribution in a closed container | prasanth | FLUENT | 3 | December 21, 2003 07:21 |
how to build solid sub-domain | RON | CFX | 3 | June 2, 2003 13:28 |
