Coal Volatilization
Old   October 15, 2008, 11:07
Default Coal Volatilization
michele
Dear all,
I want to model coal combustion using advanced kinetic scheme, like Eddy Dissipation Concept.
Is it possible with species transport model (like EDM, EDC, etc.) to define several gaseous species from volatilization of discrete phase combusting particles, or only one species can be defined?
Old   October 15, 2008, 13:02
Default Re: Coal Volatilization
Allan Walsh
What we have done is to use an intermediate volatile "species". The composition of the species can be determined from the fuel elemental composition, and the fractions of volatiles and char carbon.
Thus, the volatile species will have some composition (CxHyOz and could include S and N and others). The volatile species is set in the Fluent material panel as a gas with the appropriate molecular weight and heat of formation. (The heat of formation is the difference in the heating value of the products versus the measured heating value of the fuel).
Then we set up the appropriate reaction of Vol. Species -> xH2O + yCH4 + zCO .... including whatever gaseous species you are interested in - in the appropriate stoichiometric ratios. The reaction can be set to go instantaneously or with some delay if desired.
This approach has been satisfactory for our combustion modeling reeds.
Old   October 15, 2008, 13:48
Michele Vascellari
Thank you Allan for your answer,
Your approach is very interesting for my calculations, but I need another clarification.
How can I define the istantaneous reaction? Considering very high pre-exponential factor and low activation energy in arrhenius equation, with respect to the other reactions?
Thank you again for your help!
Michele
Old   October 16, 2008, 13:03
Allan Walsh
Setting the Arrhenius parameters will remove any kinetic limitations but sometimes the turbulent reaction rate will be limiting. If desired, the parameters in the turbulent reaction rate can be artificially increased to remove this limitation since for the psuedo volatile species, they don't have any physical meaning.
Since the fraction of fuel volatilized, and the volatiles composition, should be indexed to other factors such as the heat flux to the fuel particle, my approach has its limitations. But, I haven't had the time or initiative to try and implement a more complicated scheme.
Old   October 17, 2008, 04:19
Michele Vascellari
Thank you again for the answer,
I have another question, how do you consider the heavy hydrocarbons, like TAR, etc.?
Michele
volatilization ANDRES FLUENT 0 October 2, 2008 13:34
Coal Gasification Macy FLUENT 1 September 24, 2007 13:48
the volatilization after coating the paint Jay FLUENT 1 March 2, 2005 03:36
can Star-cd32 solve coal/non-coal particle? Leo Siemens 1 October 25, 2004 15:38
Coal with EBU Magnus CFX 2 September 14, 2001 01:34
