-   -   UDF compilation problems (http://www.cfd-online.com/Forums/fluent/49538-udf-compilation-problems.html)
MateuszZb October 16, 2008 21:01
Dear Friends
I am using Fluent 3.6.23 on a Windows XP prof 64bit with VS 2008. Unfortunatly I can not compile my UDF because of error:
c:\fluent.inc\fluent6.3.26\src\config.h(119) : error C2061: syntax error : identifier 'both' c:\fluent.inc\fluent6.3.26\src\config.h(119) : error C2059: syntax error : ';' c:\fluent.inc\fluent6.3.26\src\config.h(119) : error C2059: syntax error : ':' C:\Fluent.Inc\fluent6.3.26\cortex\src\dll.h(58) : error C2061: syntax error : identifier 'CX_DLL_GetProc' C:\Fluent.Inc\fluent6.3.26\cortex\src\dll.h(58) : error C2059: syntax error : ';' C:\Fluent.Inc\fluent6.3.26\cortex\src\dll.h(58) : error C2059: syntax error : 'type'
Did anybody handle with this problem? Please give me any advise how to manage this error or avoid it? I will be very grateful for any help
All the best
Matuesz
Anupma October 17, 2008 01:47
Gambit Problem
I got a fatal error while making a volume from faces.how do I rectify it.
sushil October 17, 2008 07:38
Re: Gambit Problem
Hi Anupama,
You can check the missing or unjoined faces with activating 'SPECIFY COLOUR MODE' tab which is located just at the right corner of the GAMBIT window next to the 'EXAMIN MESH' tab.
Once you check these faces it will be easier for you to make a volume out of it.
Regards, Sushil
RAMESH October 20, 2008 02:38
Re: Gambit Problem
i am in need of modelling ang meshing of an airfoil (NACA 0015) in gambit.
specification:
chord 30cm span 60cm slot extended up to 3cm. flap is of length 76 cm at the trailing edge.
RAMESH October 20, 2008 02:46
Re: Gambit Problem
specification:
