-   -   comparison with analytical results (1D)and(3D) CFX (http://www.cfd-online.com/Forums/fluent/49552-comparison-analytical-results-1d-3d-cfx.html)
Rogerio Fernandes Brito October 18, 2008 19:23
Hello, folks!
I´m making a comparison between ANSYS CFX-v11.0 SP1 software and analytical results from an 1D simulation from the periodical: [Z. Shijun, and L. Zhanqiang, Analytical and numerical solutions of transient heat conduction in monolayer-coated tools, Journal of Materials Processing Technology, 2008, Article in Press, doi:10.1016/j.jmatprotec.2008.05.028]. I´d like to have others opinions about my simulations. Anything wrong? The deviation that i had is about 40 %, using Al2O3 (= this is the coating) and ISO K10 (this is the cutting tool) materials (thus, there are two solids as my domains). Please, see the figure 4 "Fig. 4 â€" Influences of different coatings on temperature distribution in monolayer-coated tools" on this paper.
The files of my simulations and the paper in PDF format are at:
http://www.4shared.com/file/67475430...R_A_Z_I_L.html
or
http://rapidshare.de/files/40709654/...Z_I_L.rar.html
I will thank you for the helping.
Rogerio - MSN: rogeriobrito2007@hotmail.com - Skype: rogeriofbrito
Abstract of this paper:
The heat generation during metal cutting processes affects accuracy of the machined surface and strongly influences tool wear and tool life. Knowledge of the ways in which the tool material affects the temperature distribution is therefore essential for the study of thermal effects on tool life and workpiece quality. Many studies have been done on simulation temperature distribution in coated cutting tools by means of the finite element method or the finite difference method. In this study, a thermal analytical model is firstly developed to determine temperature distribution in monolayer-coated cutting tools during orthogonal metal cutting. In the analytical model one equivalent heat source applied on the coating layer boundary substitutes for the heat generation introduced fromthe primary deformation zone, the secondary deformation and the frictional zone along the toolâ€"chip interface as well as the tertiary or the sliding frictional zone at toolâ€"workpiece interface. A mathematical model of the transient heat conduction in monolayer-coated tools is then proposed. The temperature distribution formulations in monolayer-coated tools are obtained using Laplace transform. The influence of different parameters including thermophysical properties of tool coating and tool substrate and thickness of the coating layer on temperature distribution in monolayer-coated tools is lastly discussed and illustrated.
Conclusions:
A thermal model of one-dimensional heat transfer in monolayer-coated tools has been developed to investigate temperature distribution in orthogonal metal cutting. An analytical methodwas used to solve the transient heat conduction problem of monolayer-coated tools subjected to an equivalent constant heat flux thermal loadings of several heat sources applied on the coating boundary surface. By using the Laplace transform technique and a Taylor series expansion, analytical solutions for temperature were presented in an explicit form. The numerical solutions have shown the thermophysical parameters of coated and substrate materials have huge influences on temperature distribution in monolayer-coated tools. The analytical solution method has demonstrated that Al2O3 coating has a thermal barrier effect in heat conduction in coated tools. The coating thickness has a certain extent influence on temperature distribution in coated tools.
sivarama1 December 2, 2012 07:12
metal cutting
Dear sir,
i am doing project for metal cutting using FEA.
This is heat conduction,
Tool and geometry how to modeled and how to give boundary conditions.
i am new in this one.
Thank you
