Home > Forums > FLUENT
Heat flux through a closed window
Old   October 20, 2008, 11:39
Default Heat flux through a closed window
Stephan
Hello! I'm starting to work with FLUENT and want to simulate the flow and temperature distribution in a closed room with a radiator and a closed window. There is no air inlet or outlet, which means that energy balance can only be contained by heat flux through the thin window glass (the other real walls have a thickness of 1 m and are supposed to have a constant temperature). Is it possible to define a constant outside temperature for example as 5C, so that the heat flux in->out (driven by the temperature difference between the room and its environment) is calculated? How can I set this in FLUENT? Thanks in advance, Stephan
Thread Tools
Trackbacks are On
ratio of total heat flux and radiative heat flux S.Karthikeyan FLUENT 2 July 1, 2008 03:48
heat transfer analysis inside the closed roam san FLUENT 0 March 3, 2006 07:26
WALL HEAT FLUX V.S. HEAT FLUX tommy CFX 0 December 15, 2005 09:14
heat tran simulation two phase closed thermosyphon mohammad reza CFX 1 February 28, 2004 01:48
Heat Transfer Coeff. at Heat Flux Boundary Rushyen CFX 6 January 18, 2001 06:09
