Fluent Batch Mode Reg_ Urgent Help Required
Old   January 9, 2012, 13:11
Default Fluent Batch Mode Reg_ Urgent Help Required
deewakar
alligngr8 is on a distinguished road
Sir,
I am trying to run fluent in batch mode on windows platform. for that I have written batch file as
fluent -g -i case.jou
Howe ever when I run this batch file fluent starts its launcher, reads the journal file. Till that steps it works fine.But after that I need to manually press 'OK' to start fluent.
I have attached snap shot of what I am getting on running the batch file(also in image)
I have tried fluent 3d -g -i case.jou as well as
fluent 3d -gu -i case.jou but in both case same prob.
In fact when I write 3d or 3ddp in in front of -g and press "OK" to start running fluent it shows error that command 3ddp or 3d not recognized. So I intentionally have removed 3d.
But how to counter this.
I mean how to automate that I may not have to press "ok" again and again for multiple cases
Please guide its extremely urgent
thanks
alligngr8 is offline   Reply With Quote
Old   January 10, 2012, 10:29
Stuart Buckingham
stuart23 will become famous soon enoughstuart23 will become famous soon enough
You should not be using the '-i' flag for running a standard journal file.
Also your syntax is incorrect, you must pipe the journal file into fluent. Try:
fluent 3d -g < yourjournalfile.jou
This is correct for Unix systems, I am unsure if there is a different syntax for Windows.
Stu
PS, Please refrain from posting your question in multiple threads next time.
stuart23 is offline   Reply With Quote
Old   January 10, 2012, 11:03
deewakar
Sir,
I will keep note of not posting it in multiple forums.I apologize to all members reg same.
Could you please tell me what you mean when you standard journal file.Actually I saw the syntax in their documentation that's why I preferred to go that way. But still I will try what you have mentioned..
Thanks
Old   January 10, 2012, 20:52
Stuart Buckingham
From what I remember, the "-i" flag is used when you are passing an XML document to Fluent with session parameters. If you are passing just the journal file, you do not need the "-i" flag.
Old   January 12, 2012, 08:21
JP
srjp is on a distinguished road
fluent 3ddp -g -i case.jou is a valid batch command for Windows.
You can test this by typing "fluent 3ddp" in Start > Run
and see if Fluent starts.
there may be some problem with the fluent settings in the environmental variables for windows.
srjp is offline   Reply With Quote
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
Batch mode for a VOF Touré FLUENT 1 August 17, 2012 22:48
DPM model in parallel batch mode Prashanth FLUENT 2 March 6, 2009 07:54
how to convert .par to .geomturbo in batch mode xiaoruofu Fidelity CFD 0 December 30, 2004 04:22
Run Fluent in batch mode Shengping LUO FLUENT 2 October 24, 2000 05:42
