DPM BC Trap or Reflect
Old   October 23, 2008, 08:33
Default DPM BC Trap or Reflect
RIK
I'm trying to make a UDF to define if a particle with a diameter > then X, when hit the wall, get Trapped or Reflect. I don't know which are the functions to say Trap or Reflect to the particle. Anyone can help me with this?
Thx in advance.
Old   October 23, 2008, 23:45
Default Re: DPM BC Trap or Reflect
romans
HI, it depend on your particle, if it is liquid, choose Trap,if it is solid, choose Reflect.
Old   October 24, 2008, 04:17
RIK
The particle is solid. I need an UDF to do it, with an IF condition. Anyone knows the Trap and Reflect macro?
Old   October 24, 2008, 12:42
Allan Walsh
DEFINE_DPM_BC. The usage is described fairly well in the manual.
Old   October 24, 2008, 13:06
RIK
That don't tell me about trap or reflect.
Old   October 24, 2008, 14:37
RIK
DEFINE_DPM_BC (dpm_collision,p,t,f,f_normal,dim) {
if (P_DIAM(p)<5e-6)
X
else
Y
I already had this...but where is X and Y should be 2 functions that tell the program to make the particle REFLECT or TRAP. Is just that info i need. I found in dpm.h this: #define DPM_BC_REFLECT 2 #define DPM_BC_TRAP 3
Don't know how to use them, i tried all ways i could remember and the FLUENT still not trap particles.
Anyone knows how to solve this???
Old   October 27, 2008, 12:04
Default Re: DPM BC Trap or Reflect *NM*
Allan Walsh
Old   October 27, 2008, 12:06
Allan Walsh
For trapped, use return PATH_END and increase the variable for the number of particles trapped. For reflect, return PATH_ACTIVE.
Old   October 28, 2008, 06:09
RIK
Thanks for your help. But when i use PATH_ACTIVE that don't let me choose the reflection parameters, there is other function?
UDF for trap of dpm HK FLUENT 2 November 8, 2016 09:43
Reflect in TGrid Vivek Vasudevan Main CFD Forum 0 March 16, 2007 08:58
Reflect in TGrid Vivek Vasudevan FLUENT 0 March 15, 2007 22:02
DPM, B.C.--reflect, escape, trap. Any else? zhang FLUENT 1 February 27, 2004 13:57
Gambit copy/reflect operation Laurence Wallian FLUENT 3 October 8, 2003 04:29
