Home > Forums > FLUENT
Combination of Hex and Tet-Elements in GAMBIT
Old   October 25, 2008, 07:34
Default Combination of Hex and Tet-Elements in GAMBIT
Sebastian Gatzka
Hello World.
I'm trying to mesh a volume. Unfortunately (or as a matter of fact) the computational domain contains a radius.
I still want to use hexahedron elements in the main part of the computational domain, so I decided to mesh the part near the radius with tetrahedron elements to deal with the radius.
Have a look at the picture, which will illustrate the problem: http://therealsega.th.funpic.de/open...tetra_area.jpg
The complete domain is still defined as one volume (and a volume group as well).
So, how is it possible to tell GAMBIT to mesh with tetrahedron elements in the designated area and to mesh with hexahedron element in the rest?
Maybe I have to split the domain, but I don't know how this can be achieved.
Thanks for your help. Sebastian
Old   October 27, 2008, 13:07
Default Re: Combination of Hex and Tet-Elements in GAMBIT
JB
Correct, you should split your domain in 3 volumes. I see from the picture that you already defined 2 faces. Just split your main volume with those faces
geometry -> volume -> split volume -> split with: faces (real)
BTW: I'm afraid your mesh will have poor quality if you fill the in between volume with tet elements..
I hope this helps! /JB
Old   October 27, 2008, 14:59
Sebastian Gatzka
Thank you JB.
I toyed around with GAMBIT and found a way to created the desired mesh.
http://therealsega.th.funpic.de/openfoam/finalmesh.jpg
I think in this combination the quality is not as bad as it would have been in the first approach ... Or do you think different?
Old   October 28, 2008, 01:45
mAx
switch your tetra-volume into pave-volume, and you will have only hexa-
Old   October 28, 2008, 05:52
JB
Yeah I think it was a good Idea to do what you did. You improved the mesh quality for sure.
Regarding element type, it really depends on what you're simulating.
Cheers /JB
Thread Tools
Trackbacks are On
inverted elements in gambit ak FLUENT 0 September 27, 2007 00:53
what to do w/ highly skewed elements? (GAMBIT) mike FLUENT 5 June 2, 2007 22:10
Inverted elements in gambit Geoffroy Chaussonnet FLUENT 2 April 25, 2007 01:43
active analysis elements in GAMBIT yan FLUENT 0 April 28, 2006 01:46
How to use GAMBIT and Fluent5.1 for rotatory elements RAVINDER YERRAM Main CFD Forum 1 November 14, 1999 21:21
