-   -   Problem in compiling property(density) UDF (http://www.cfd-online.com/Forums/fluent/49666-problem-compiling-property-density-udf.html)
satish2968 October 31, 2008 05:18
Hi Fluent Users,
I have great difficulty in figuring out my problem.
i had written a property udf for density which follows isentropic law:
p/rho^gamma= constant; actually my problem is to predict compressibility effects in incompressible flow through obstruction type flow meters.
so the compressible fluid in incompressible flow follows a isentropic law and it's udf is:
#include "udf.h" DEFINE_PROPERTY(cell_density,cell,thread)
real density; real pressure = C_P(cell,thread); density = pow((pressure/80756.35),1.0/1.4); return density;
value 80756.35 is equal to initial pressure/initial denisty^1.4
101325/1.176^1.4=80756.35 during the flow from inlet to outlet density has to vary with respect to pressure variation following isentropic law
libudf was successfully built
loaded successfully
when i am trying to initialise the solution from inlet
it is showing fatal error access voilation
please help me anybody my project thesis is depends on this problem.
max October 31, 2008 06:23
Re: Problem in compiling property(density) UDF
What is the value for pressure you are initializing? If it is zero your udf will return a density of zero as well which might be the reason for the error.
Max
rajesh October 31, 2008 15:25
Try this and let me know if it helps. while initializing the solution, do not select inlet from the drop-down list, instead type in all the quantities for inlet velocity, temp.... etc. for initializing the solution and then initialize.
satish October 31, 2008 16:06
Hi Rajesh,
Thank you for the suggestion and problem is that i know only gauge initial pressure to initialise the solution
one of my friend suggested me that
I should for all zones in the drop down box or simple have to click on the init button
otherwise trying to solve with constant density for 10^-3 convergence and then compiling density udf for further solution by which it will have sufficient pressure field to calculate per cell basis density from available pressure field
Please suggest me if u understand anything
