-   -   compiling udf error help (http://www.cfd-online.com/Forums/fluent/49722-compiling-udf-error-help.html)
venkatesh4386@gmail.com November 6, 2008 13:05
im using linux os 64 when i try to 'BUILD' my udf in fluent i get the error
"cat: log: no such file or directory."
i am able to INTERPRET the same udf in fluent without error.the case and data files are in tha same folder.
when i tried to load it, it gives error msg as
"open_udf_library: no such file or directory"
in the TERMINAL im getting message as
"make: Warning: File `Makefile' has modification time 1.3e+03 s in the future make: warning: Clock skew detected. Your build may be incomplete."
THANKS IN ADVANCE,
VENKAT
e0125583 November 7, 2008 03:20
Re: compiling udf error help
what FLUENT version do you use? do you run fluent in 64bit-mode? in FLUENT 6.2 you have to run in 64bit-mode when you use 64bit os. dont know why.
