-   -   IcePak network objects in parallel solver (http://www.cfd-online.com/Forums/fluent/49783-icepak-network-objects-parallel-solver.html)
Alexey November 13, 2008 10:05
Can I use network objects in large models, which may be solved only on multiprocessor systems?
I have tried to solve simple model with network objects and IcePak have switched on serial solver with log: Warning: the parallel solver does not support network objects Switching to the serial solver
Is it principal restriction of IcePak/Fluent?
Jupudi.pramodh December 25, 2013 09:32
Hi Buddy,
It used to be a restriction in the previous versions. But as the latest versions are rolling out, the developers are slowly upgrading these hurdles one by one.
Similar to the one you have mentioned, i was facing problem with ray tracing radiation model (Icepak was not able to pick parallel solver). But as the latest version rolled out, this problem is rectified.
thanks
Pramodh J
