FLUENT 12 cylindrical subdomain setup
Old   October 29, 2010, 19:10
Default FLUENT 12 cylindrical subdomain setup
aerospain
aerospain is on a distinguished road
Send a message via Skype™ to aerospain
Hi all,
I am having some trouble setting up a geomtrically simplified problem. As you can see in the picture attached, my 3D subdomain is a 12th of a cylinder which is attached to some tubing at an outer diameter distance.
The flow goes in through the inlet on the left hand side of the picture, and comes out from the outlet on the right hand side upper corner, even though it says "inlet" (in red), apologies.
The flow works as a coolant for the solid which is not shown (only the internal fluid volumes are shown) This solid, say a cylinder, spins about the main axis at a known rpm.
So, I know my inlet speed, my rpm's, where my walls, my inlet and my outlet are. But what type of boundary should I define the ones signaled by the purple arrows as? And, How do I setup the rotational speed of the system? Do I apply it as a rotational speed to the walls being defined as "moving walls"? Do I also apply a rotational speed to the fluid volumes defined by FLUENT? Do I apply one of the two or both of them?
Thanx in advance
aerospain is offline   Reply With Quote
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 19:12
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 12:07
Kenics mixer fluent setup ankur gupta FLUENT 0 August 12, 2010 07:34
Fluent 6.3.26 vs 12.1 and partition method Anorky FLUENT 0 April 27, 2010 10:55
