monitor pressure
I have a question concerned about pressure monitoring in transient analysis. I want to monitor the pressure at a point that i have create in Point Surface.
After that i go to Solve>Monitors>Surface>check plot,print,write when time step>Define (select the created point, report Pressure at Static, report type integral)>ok when i iterate the model, my monitor's window just show the straight line at 0 Pascal in each time step. What should i do to get the correct pressure graph? |
Re: monitor pressure
A point has zero surface area so selecting integral for a point will always give you zero.
Try using average for the report type at the point. |
Thank you CDE.
I have change it to vertex average for report type,it's really work but i found the pressure graph show in monitor's window higher than total pressure that i set in inlet boundary conditions. How to solve this problem? |
What inlet and outlet boundary conditions are you using?
Are you monitoring static pressure or total pressure? |
Reply CDE,
i use Pressure_inlet and pressure_outlet as my inlet and outlet. i monitor static pressure. what is your opinion about this setting? |
I did a temperature monitoring point, but when i openned the file of this monitoring, i found only this message:
"Convergence history of Total Temperature on point-5 (in SI units)" "Iteration" "Facet Average Total Temperature" One question: where are the results of the temperature field in my transient simulation. The files are in: http://rapidshare.de/files/40970125/...teste.rar.html Thanks! |
