November 22, 2008, 12:17 |
parallel procesing
Dear All
I am trying to run parallel procesing with fluent but still I am getting mesage like: Starting /home/oem/fluent/Fluent.Inc/fluent6.3.26/multiport/mpi/lnamd64/hp/bin/mpirun -np 4 /home/oem/fluent/Fluent.Inc/fluent6.3.26/lnamd64/3ddp_node/fluent_mpi.6.3.26 node -mpiw hp -pic ethernet -mport 127.0.0.2:127.0.0.2:24788:0 mpirun: rsh: Command not found. Could you please help me? What should I do in this case? I look forward to hearing from you. All the best MAT |
November 23, 2008, 10:18 |
Re: parallel procesing
November 23, 2008, 14:39 |
Thank you very much for the pdf file. I have gone through this tutorial and still I have the same message Host spawning Node 0 on machine "linux-t1ck" (unix). /home/oem/fluent/Fluent.Inc/fluent6.3.26/bin/fluent -r6.3.26 3ddp -node -t2 -pethernet -mpi=hp -mport 127.0.0.2:127.0.0.2:13302:0 Starting /home/oem/fluent/Fluent.Inc/fluent6.3.26/multiport/mpi/lnamd64/hp/bin/mpirun -np 2 /home/oem/fluent/Fluent.Inc/fluent6.3.26/lnamd64/3ddp_node/fluent_mpi.6.3.26 node -mpiw hp -pic ethernet -mport 127.0.0.2:127.0.0.2:13302:0 mpirun: rsh: Command not found\ Do you have any clue what I am doing wrong or what I should do in this case? I look forward to hearing from you. All the best Mat |
November 23, 2008, 15:02 |
I just work with CFX and i´m new in fluent!
November 23, 2008, 22:33 |
OK. Thank you
November 25, 2008, 17:07 |
as i can see you haven't set fluent command in your PATH I mean you cannot type "fluent" in a shell and Fluent will work. Am i right? Try to fix this. An it will probably work. Try this and we are here for more help. Cheers |
November 25, 2008, 22:01 |
Thank you for replay. I have defined fluent command in the path. I can type "fluent" and it is working. I tried as well to start Using Command Line Options and Using the Graphical User Interface and still nothing. Do you have any clue what can be wrong? All the best Mat |
November 26, 2008, 14:05 |
If you can try starting FLuent like this:
fluent 2ddp -t2 -ssh this tellas Fluent to open as 2ddp in two processes with ssh. Try this. |
November 27, 2008, 00:45 |
#9 |
Thank you very much. It is working! I was using this command as well but without -ssh, and I was always getting the same error. What does it mean -ssh? Once again, thanks a lot All the best Mat |
November 27, 2008, 04:06 |
#10 |
ssh means that it will use the secure shell for comunications and not rsh.
I am glad that I could help you. Best. |
November 27, 2008, 07:35 |
#11 |
Thank you once again.
All the best and see you some where some how Mat |
Parallel UDF | Karo | FLUENT | 2 | April 25, 2017 01:36 |
UDF parallel | Lucy | Fluent UDF and Scheme Programming | 3 | May 28, 2013 13:14 |
Where is my Parallel Log | andrewburns | OpenFOAM Running, Solving & CFD | 5 | February 4, 2008 23:07 |
cfx parallel | Rao | CFX | 7 | April 16, 2004 23:53 |
Parallel run | Bogdan | Siemens | 2 | June 26, 2002 10:31 |
