Home > Forums > FLUENT
How to patch initial disturbance on free surface
Old   November 26, 2008, 08:17
Default How to patch initial disturbance on free surface
Ted Chu
Hi all,
I would like to know how to patch a wave profile on the free surface as an initial condition. It is a 2D case. VOF is used. Air and water. The wave will go from left to right.
Thanks...
Old   November 26, 2008, 08:24
Default Re: How to patch initial disturbance on free surfa
k.baker
is it a stratified flow case?
Old   November 26, 2008, 10:38
shoushibo
you can use DEFINE_INIT macro. by judging the relationship between the y coordinate of the cell and the wave profile you can patch the vof is one
Old   November 26, 2008, 12:21
Ted Chu
I guess it is a stratified flow case. Air is on the top, and water is on the bottom. Both are fluids. But, correct me if I am wrong..
Old   November 26, 2008, 12:33
Ted Chu
Thanks shoushibo. By the way, do you have a cas file and the DEFINE_INIT udf which you had patched an initial free surface profile?? I am doing a term project for a class, so kind of in a hurry. Many thanks to you in advance....
Old   November 26, 2008, 13:57
k.baker
is it a pipe flow? you work currently with 2D or 3D? what you want to predict in addition to free surface fluctuations?
Old   November 26, 2008, 14:04
BOHIS
Hi there, I think that Mr. Baker knows me very well. Let me say hello to him! By the way, if you tend to have smooth initial interface, you should put command (rpsetvar 'patch/vof? #t) in TUI before initialization.
good luck
Old   November 26, 2008, 14:13
k.baker
Hey Bohis thanks a lot for your reply with this please tell us in which option in TUI this facility to getting smooth free surface was available?
Old   November 26, 2008, 22:32
Ted Chu
Thank you guys for sharing tips. To answer Mr. Baker's question, I am doing a solitary wave propagation simulation. It is a 2D case. The wave will travel from left to right. The free surface fluctuation will be the only focus. I know how to patch undisturbed free surface into the domain, but don't know how to patch the initial wave profile. shoushibo suggested using DEFINE_INIT. I am trying it now. Do you guys do it differently??
At the mean time, I am moving the left boundary as a wavemaker. But, as we know, it is hard to produce a pure solitary wave this way. The tailing waves always exist.
Old   November 27, 2008, 10:31
bohis
Hi guys, actually I do not know how (rpsetvar 'patch/vof? #t) really works. rpsetvar is scheme command which sets the variable patch/vof. If you use #t, then the interface will be smooth. If you use #f, it will be sharp. You should type it directly as a command in TUI before first initialization.No more questions about it, I do not know more (note: I have never tried it with udf initialization - DEFINE_INIT) As regards patching, you can either create register using adaption panel or if the shape is complicated, then use UDF.
good luck
Old   November 27, 2008, 10:47
  #11
shoushibo
if you need a case about define_init macro ,i can provide,please leave a email.
Old   November 27, 2008, 11:17
  #12
Ted Chu
Thanks shoushibo. I'd really appreciate it. My email address is yutechu@hotmail.com.
Thanks bohis for your input.
Thread Tools
Trackbacks are On
free surface initial conditions John N. CFX 1 March 12, 2009 17:18
Transient free surface with initial conditions Juan Catelén CFX 4 September 3, 2007 08:54
Divergence free initial field maka OpenFOAM Pre-Processing 2 October 26, 2005 08:52
Free surface flow,Initial & B.C.s?(URGENT) tuks CFX 0 August 24, 2004 09:08
difference between PATCH and INITIAL zwdi FLUENT 2 September 17, 2003 14:46
