Including Gravity Component
Old   November 29, 2008, 18:33
Default Including Gravity Component
Robert
I am modeling a boat moving through water. Because I am not very experienced with Fluent, I simplified the modeling and had the boat stationary with the water having velocity. I am looking at the y component of the water and would like to show the static pressure changing with the height of water. I assume I would need to use the gravity component in Fluent but when I check it under the Operating Conditions panel, there is no change in results.
Old   November 30, 2008, 16:05
Default Re: Including Gravity Component
CDE
you also need to enable the Specified Operating Density in the Operating Conditions panel and set it equal to zero. This enables the hydrostatic head calculation in FLUENT.
Including a new utility in OF 13 alondono OpenFOAM Running, Solving & CFD 7 April 11, 2008 09:17
Gravity component and inlet velocity Vidya FLUENT 8 July 31, 2006 08:28
gravity-table.scm scheme file for trans gravity Shankar FLUENT 0 May 31, 2006 04:30
including gravity in 1D model Amir Filipovic Main CFD Forum 0 November 18, 2003 15:23
Including gravity in calculations!!! gilberto CFX 26 October 15, 2001 20:55
