-   FLUENT (
-   -   fluent flow problem (
Tony December 4, 2008 08:20
fluent flow problem
i am trying to model simple flow in a pipe with a cavity.
my boundary conditions are
inlet: 0.1mpa (absolute pressure) turbulence intensity 5% turbulence length scale 66.00mm mass flow rate 0.305kg/s
atmospheric pressure i.e. guage=0 turbulence intensity 0.1% length scale 0.66mm
wanting to have a mass flow inlet and 0 guage pressure outlet but having problems solving as fluent is giving me errors-'absolute pressure limted' and ' problem with amg solver:pressure'
i am using second order wind solvers and the k epsilon turbulence model.
canyone help?
mAx December 4, 2008 10:00
Re: fluent flow problem
is your model right scaled? (eg: m, cm or mm, etc...?) check in define/scale
instead of massflow-inlet & pressure-outlet, try velocity-inlet & pressure-outlet
Tony December 4, 2008 10:16
have checked scale and used a velocity inlet but getting same problem roughly after 35 iterations or so.
have calculated a velocity inlety of 87.834 m/s with temp of 291.0 k, turbulence intensity =5% and scale=66mm
have set my outlet to guage pressure= 0 with turbulence scale =0.1 and scale 66mm (diameter of flow) getting same problem ;
turbulence viscosity limited to viscosity ratio of 1.000e+05 absolute pressure limited to 1.00000e+00
then finally;
divergence detected in AMG solver:pressure correction
mAx December 4, 2008 10:29
*is the massflow conserved between inlet/outlet? (report/fluxes)
*switch to first order
*try several method for initialization
*is your mesh ok? (grid/check) (grid/info/quality)
if you still have troubles, zip your case file, and give me per mail a link where you shared it (rapidshare, etc...), I will take a loot at it, tomorrow
