fluent flow problem
Old   December 4, 2008, 07:20
Default fluent flow problem
Tony
i am trying to model simple flow in a pipe with a cavity.
my boundary conditions are
inlet: 0.1mpa (absolute pressure) turbulence intensity 5% turbulence length scale 66.00mm mass flow rate 0.305kg/s
outlet;
atmospheric pressure i.e. guage=0 turbulence intensity 0.1% length scale 0.66mm
wanting to have a mass flow inlet and 0 guage pressure outlet but having problems solving as fluent is giving me errors-'absolute pressure limted' and ' problem with amg solverressure'
i am using second order wind solvers and the k epsilon turbulence model.
canyone help?
Old   December 4, 2008, 09:00
Default Re: fluent flow problem
mAx
is your model right scaled? (eg: m, cm or mm, etc...?) check in define/scale
instead of massflow-inlet & pressure-outlet, try velocity-inlet & pressure-outlet
Old   December 4, 2008, 09:16
Tony
have checked scale and used a velocity inlet but getting same problem roughly after 35 iterations or so.
have calculated a velocity inlety of 87.834 m/s with temp of 291.0 k, turbulence intensity =5% and scale=66mm
have set my outlet to guage pressure= 0 with turbulence scale =0.1 and scale 66mm (diameter of flow) getting same problem ;
turbulence viscosity limited to viscosity ratio of 1.000e+05 absolute pressure limited to 1.00000e+00
then finally;
divergence detected in AMG solverressure correction
Old   December 4, 2008, 09:29
mAx
*is the massflow conserved between inlet/outlet? (report/fluxes)
*switch to first order
*try several method for initialization
*is your mesh ok? (grid/check) (grid/info/quality)
if you still have troubles, zip your case file, and give me per mail a link where you shared it (rapidshare, etc...), I will take a loot at it, tomorrow
good cold flow results but problem with hot flow Rams FLUENT 0 June 20, 2006 00:52
good Cold Flow Results but problem with Hot Flow Rams FLUENT 1 June 18, 2006 19:59
good cold flow results but problem with hot flow,. Rams FLUENT 0 June 13, 2006 11:08
good Cold Flow Results but problem with Hot Flow Rams CFX 2 June 13, 2006 03:30
Simulation of Two Phase Fluid Flow Problem Using Fluent 5.0 Mohammad Al-Shannag Main CFD Forum 1 July 16, 1999 11:28
