December 4, 2008, 07:20 |
fluent flow problem
i am trying to model simple flow in a pipe with a cavity. my boundary conditions are inlet: 0.1mpa (absolute pressure) turbulence intensity 5% turbulence length scale 66.00mm mass flow rate 0.305kg/s outlet; atmospheric pressure i.e. guage=0 turbulence intensity 0.1% length scale 0.66mm wanting to have a mass flow inlet and 0 guage pressure outlet but having problems solving as fluent is giving me errors-'absolute pressure limted' and ' problem with amg solverressure' i am using second order wind solvers and the k epsilon turbulence model. canyone help? |
December 4, 2008, 09:00 |
Re: fluent flow problem
is your model right scaled? (eg: m, cm or mm, etc...?) check in define/scale
instead of massflow-inlet & pressure-outlet, try velocity-inlet & pressure-outlet |
December 4, 2008, 09:16 |
have checked scale and used a velocity inlet but getting same problem roughly after 35 iterations or so.
have calculated a velocity inlety of 87.834 m/s with temp of 291.0 k, turbulence intensity =5% and scale=66mm have set my outlet to guage pressure= 0 with turbulence scale =0.1 and scale 66mm (diameter of flow) getting same problem ; turbulence viscosity limited to viscosity ratio of 1.000e+05 absolute pressure limited to 1.00000e+00 then finally; divergence detected in AMG solverressure correction |
December 4, 2008, 09:29 |
*is the massflow conserved between inlet/outlet? (report/fluxes)
*switch to first order *try several method for initialization *is your mesh ok? (grid/check) (grid/info/quality) if you still have troubles, zip your case file, and give me per mail a link where you shared it (rapidshare, etc...), I will take a loot at it, tomorrow |
good cold flow results but problem with hot flow | Rams | FLUENT | 0 | June 20, 2006 00:52 |
good Cold Flow Results but problem with Hot Flow | Rams | FLUENT | 1 | June 18, 2006 19:59 |
good cold flow results but problem with hot flow,. | Rams | FLUENT | 0 | June 13, 2006 11:08 |
good Cold Flow Results but problem with Hot Flow | Rams | CFX | 2 | June 13, 2006 03:30 |
Simulation of Two Phase Fluid Flow Problem Using Fluent 5.0 | Mohammad Al-Shannag | Main CFD Forum | 1 | July 16, 1999 11:28 |
