Surface in the middle of volume?
Old   December 5, 2008, 09:45
Default Surface in the middle of volume?
JP
Hello All,
perhaps someone could help here: I have an air-filled volume V. In the middle of V there is a surface sheet S (single face). Is it possible to mesh V and define S as a "wall" in GAMBIT and export this mesh to FLUENT?
My problem here is that S is not really a "wall" of the volume V. It hangs freely in V and doesn't touch the walls of V. How is the mesh of V going to refer to the surface S? I have no answer here.
Any ideas?...
Old   December 5, 2008, 10:42
Default Re: Surface in the middle of volume?
Luca
You can divide the volume in 2 sub-volumes, adding a face (or more than one, depending on the geometry). The added face(s) wil be defined as INTERIOR, while the one you mentioned will be defined as WALL. At this point, you have to define a fluid domain that includes the two volumes. The mesh on the face defined as WALL, is duplicated in fluent, that creates a "shadow" face. There is nothing more to do, your job is done.
Ciao
Old   December 5, 2008, 11:52
JP
If I understand you correctly - my surface S has to be the boundary wall between two fluid volumes, correct?
Old   December 5, 2008, 12:25
Luca
Yes, the volumes are separated by different surfaces, some defined as INTERIOR and one as WALL.
Old   December 5, 2008, 12:48
JP
That is the problem, though. What you sugest - I have done it before and it works. But you need 2 well-defined volumes. Now my surface S is a corkscrew surface and can't separate a volume in two.
So if there is another trick possibly... Many thanks for your replies so far
Create a surface inside a volume Michael CFX 1 February 4, 2009 16:42
Free surface volume problem Yogesh prajapati FLUENT 0 July 24, 2008 01:33
"surface tracking" and "volume of fluid" ztdep Main CFD Forum 3 April 30, 2006 15:21
Surface and Volume Integrals philippe FLUENT 5 June 22, 2005 01:00
creating volume from a surface file for CFD Amir Main CFD Forum 0 December 24, 2002 02:08
