importing Icem mesh into Gambit
Old   December 6, 2008, 02:44
Default importing Icem mesh into Gambit
srinivas
Hii....I am facing a problem while importing a hybrid mesh, which is created in ICEMCFD, into gambit. Actually i created a half mesh in ICEMCFD and try to reflecting the other half but it is giving some interface problems..so i am trying to mirroring in Gambit.
Old   December 10, 2008, 03:51
Default Re: importing Icem mesh into Gambit
Wifi Lee
You can set the mirror face internal.
Old   December 11, 2008, 22:01
srinivas
while importing itself it is giving problem.
Old   December 12, 2008, 03:58
Uday
Hi srinavas
You can mirror the mesh in icem it self it has the capability. The reason why i am insisting you to do it icem is gambit needs geometrical definations for that mesh so it would be very cumbersome long process. If you have some idea in icem copy that mesh against the mirror plane and even icem will ask you if you want to merge the nodes of that mirror copy and original copy.(tetra mesh)
or
You can export a *.msh file from icem read it in Tgrid and then mirror it which would be more easier then the gambit process.
If its not possible mail me the mesh at udayrg@gmail.com zipped i would do it for you.
Regards Uday
Old   December 12, 2008, 04:06
Uday
Ok you have the project file for icem rght
Go to edit mesh option and the that select mesh transformation tool
once you go there you would have four options the third one is for mirroring put on copy option and merge nodes option automatic and even delete duplicate node option select the refelction axis or plane according to you geometry and its done.
regards
uday
Importing a mesh from ICEM Waseem Siddique Siemens 14 February 9, 2009 05:05
[Commercial meshers] Importing a hex core mesh from Gambit dmoroian OpenFOAM Meshing & Mesh Conversion 6 September 18, 2006 02:45
Importing Patran mesh into Gambit Trac FLUENT 1 September 29, 2005 10:32
importing mesh from ICEM CFD into CFX 5 Jay CFX 2 November 12, 2002 13:46
