December 11, 2008, 01:51 |
MODELING TWO MATERIALS IN FLUENT
I would like to know if it's possible to model two types of materials in FLUENT. For example would it be possible to allow dust AND air to travel through an inlet and through a duct - and then eventually seperate with the air passing through a vent? Almost like what a centrifuge does. I'm new to FLUENT so any ideas would be extremely helpful! Thank you! |
December 19, 2008, 03:29 |
Re: MODELING TWO MATERIALS IN FLUENT
You should use a multiphase model where you can asign different material phases. Fluents Users Guide explains very well which of the available multiphase models is most appropriate for each case of multiphase flow.
The available multiphase models are The Eulerian Model (more suitable for granular flows) The mixture Model The VOF Model I think that the Eulerian Model seemms more suitable for your case. |
December 25, 2008, 23:09 |
Actullay I guess for this case you could just use the dpm model. That is if dust volume fraction is low enough in the mixture.
EHD modeling with FLUENT | Ramin | FLUENT | 10 | July 12, 2014 07:26 |
new materials in fluent by mixing other materials | Anna | FLUENT | 0 | January 18, 2009 04:53 |
How to change the materials diameter in Fluent | pc | FLUENT | 1 | August 11, 2008 07:20 |
modeling in fluent | amir | FLUENT | 2 | December 12, 2005 01:43 |
define materials in ASM modeling | cwflying | FLUENT | 2 | May 29, 2002 21:12 |
