Error Msg FLUENT: Time step reduction
Old   December 18, 2008, 04:42
Default Error Msg FLUENT: Time step reduction
Ali Sarosh
Hi everyone While using density solver,I keep getting the message "time step reduction in -- cell" , everytime I switch from first to higher order discretization while simulating supersonic combustion flow. There is only a temporary improvement if I reduce the Courant No. Can anyone Plz tell me why this message appears and how to get rid of it....because the results become absolutely erroneous after the message. Thanx ALI
Old   December 18, 2008, 12:23
Default Re: Error Msg FLUENT: Time step reduction
zongtwi
I have been told that the core numerics of FLUENT 6.3 does produce errors when you change from lower to higher order discretization schemes. In FLUENT 12, a new algorithm has been introduced that slowly blends the formulation from first order to second order schemes. It may not be the same problem that you are facing right now, but you might want to try out the FLUENT 12 Beta version and see if your problem can be solved.
Hope that helps.
batch command to run fluent from nth time step solomon FLUENT 13 August 25, 2015 20:05
SELECTING TIME STEP SIZE, NUMBER OF TIME STEP NITUL KALITA FLUENT 2 November 22, 2012 08:28
Time accuracy of NITA - FRACTIONAL STEP in Fluent Paolo Lampitella Main CFD Forum 0 March 19, 2008 07:20
Time Step Size for Airfoil Model - Fluent Prateek Main CFD Forum 0 November 4, 2004 18:42
On the reduction of cpu time lee Main CFD Forum 4 March 7, 1999 22:02
