Best Pc Configuration for maximum simulation speed
Hi all,
I am using Kubuntu 7 32 bit and fluent 6.3 32 bit in a dual core pc with 3 G of RAM memory. If i wil use Kubuntu 64 bit and fluent 64 bit in a dual core pc with 4 g Ram, is there going to be any substantial difference in the simulation speed. Generally which is the optimum pc configuration in order to have maximum simulation speed. Thanks in Advance, Anastasios |
Re: Best Pc Configuration for maximum simulation s
using 64bit will allow you to increase your memory higher then 4GBRAM. Having higher RAM will speed up your simulation.
Maximum simulation speed is very subjective. I personally would recommend you to use a 64bit machine with atleast 8GB of RAM. this should give very good simulation performance. |
Thanks very much for your response, zongtwi
I will try to follow your advise. thanks again |
