Errors when Compiling UDF: error C2040/error C2099 |
December 19, 2008, 04:30 |
Hallo,
I would like to use a very simple UDF, which writes informations of particles into a file. For compiling the UDF, I downloaded 'Visual C++ 2008 Express', go to the 'libudf\ntx86\3d>' directory and type 'nmake'. Here is my UDF-Code: ------------------------------------------------------------ /*#define USE_FLUENT_IO_API 1*/ #define USE_FLUENT_IO_API 0 #include "udf.h" FILE *fp; fp = fopen ("myfile.txt","w"); DEFINE_DPM_OUTPUT(discrete_phase_sample,header,fp, p,t,plane) { float x,y,z; x = P_POS(p)[0]; y = P_POS(p)[1]; z = P_POS(p)[2]; fprintf(fp,"%d %f %f %f\n",p->part_id, x, y, z); } ------------------------------------------------------------ Quite simple I guess, but anyhow, my computer doesn't like the 'FILE' command. Here is what I get, after I typed 'nmake': ------------------------------------------------------------ Setting environment for using Microsoft Visual Studio 2008 x86 tools. c:\Users\Casper\Desktop\UDF-test\libudf\ntx86\3d>nmake Microsoft (R) Program Maintenance Utility Version 9.00.30729.01 Copyright (C) Microsoft Corporation. All rights reserved. cl /c /Za /DUDF_EXPORTING -Ic:\fluent.inc\fluent6.3.26\ntx86\3d -Ic:\fl uent.inc\fluent6.3.26\src -Ic:\fluent.inc\fluent6.3.26\cortex\src -Ic:\fluent. inc\fluent6.3.26\client\src -Ic:\fluent.inc\fluent6.3.26\tgrid\src -Ic:\fluent .inc\fluent6.3.26\multiport\src ..\..\src\dpm_counter.c Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86 Copyright (C) Microsoft Corporation. All rights reserved. dpm_counter.c ..\..\src\dpm_counter.c(14) : error C2040: 'pFile' : 'int' differs in levels of indirection from 'FILE *' ..\..\src\dpm_counter.c(14) : error C2099: initializer is not a constant NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio 9.0\VC\BIN \cl.EXE"' : return code '0x2' Stop. c:\Users\Casper\Desktop\UDF-test\libudf\ntx86\3d> ------------------------------------------------------------ Here are some information about my system: Windows Vista 32-bit dual-core 1.6GH 64-bit Fluent 6.3 Visual C++ 2008 Express Edition I searched the Forum and the internet for some solution but couldn't find any. Hope, you can help me, best wishes, Julian |
December 21, 2008, 00:23 |
Re: Errors when Compiling UDF: error C2040/error C
Hai
try to start fluent from Vc++ command prompt and then compile udf.. Hopefully it will work. almost all the 'nmake' error occurs because of this. regards sk. |
compiling udf error help | venkatesh4386@gmail.com | FLUENT | 1 | November 7, 2008 02:20 |
UDF error in compiling | Shin | FLUENT | 1 | December 15, 2007 20:25 |
Compiling ERROR | hans007 | FLUENT | 0 | December 12, 2007 04:58 |
Compiling Error in 6.1 | Matthew Brannock | FLUENT | 2 | April 3, 2003 22:34 |
Error while compiling UDF | Sridhar | FLUENT | 0 | August 7, 2001 11:02 |
