UDF for heat source
hi,
i am a beginner for fluent, i need to assign a constant heat source in a specific place. its an axisymmetric problem. its like a rectangle box (.7x.4) m dimension and i need to assign constant heat source about .1m from bottom. please if some one help me. thank you |
Re: UDF for heat source
sorry cylindrical tube! not rectangular box.
If you are not familiar with UDFs, why not just set the region as a separate volume (it can be thin) and then just use the GUI to specify a constant source?
when i tried to create volume it shows an error: cannot create ACIS body. Is this an open shell? what can i do plz advice. its a 2d problem so i don't have few faeces to stitch together. Thank you for your time. |
Ok, in 2-D make, your region for the heat source to be a separate face and apply a heat source in that region.
Re: UDF for specific heat cp
please, somebody who helps me to make a udf for the specific heat CP for fluent.
