Initialization problem
Old   January 2, 2009, 01:06
Default Initialization problem
Parag Gadgil
I am simulating an air intake system with two inlets with Fluent. The problem is that the intake system has two separate inlets which are completely disconnected from each other.
Please let me know,how can such a simulation be initialized using Fluent.
Regards, Parag
Old   January 2, 2009, 03:02
Default Re: Initialization problem
sushil
You mean to say there are two distinct domain..?
Old   January 2, 2009, 20:43
Uday
HI,
Parag,
As sushil says if you have to distinct domains you can intialize form one inlet both domains and then the other domain you can patch intialize to some value closer to your other inlet b.c.
or
in second secnario if its a single domain you can intialize with all zones ref. which would be the best case in above 1 st secnario even you can do the same however the intialization is nothing but a value in each cell by which the simulation should start. Closer you are to the real values faster will be you convergence.The case can run with zero values even but which may take long time to reach convergence and some peculiar physics case might have stability problem with zero intialization.
Uday regards
PtrList initialization problem mateusz_slowikowski OpenFOAM Running, Solving & CFD 8 March 19, 2012 14:32
Initialization problem when using Axisymmetry BC Eduardo FLUENT 0 August 4, 2008 09:23
initialization kunal FLUENT 5 April 17, 2008 22:45
coal combustion initialization problem Chetan Prahsant CFX 1 May 1, 2007 05:41
Initialization Problem...Please Help!!! Ryan FLUENT 4 July 28, 2006 19:13
