Home > Forums > FLUENT
Problem with turbulent models
Old   January 3, 2009, 09:41
Default Problem with turbulent models
kostas
Hi. I have a airfoil and when i solute it with a k-e model (enhanced wall) with y+=0.2-1.3, i take wrong results... When i solute it with spalart-almaras with same y+, i take a good approximation. Why occur this with k-e model? What do must i, for use the k-e model? expect the configuration of y+, must i config other parameters??
Old   January 3, 2009, 11:54
Default Re: Problem with turbulent models
zongtwi
If your Y+ values is around 1, you should use the enhance wall treatment with the k-e model. This should improve your results.
Hope that helps.
Old   January 3, 2009, 14:19
igor
why do you not use k-e model and a mesh with y+ = 20-40?
Old   January 3, 2009, 16:45
kostas
So. I solute the airfoil with k-e model and i see after that i have Y plus approximately 0.4-0.5. The results are wrong (the low pressure of up section is at back of section which is wrong because my experiments have the low pressure in front of section.).
when i try to use wall functions, must make a big length of first node and again i take the same results...
Only, with spalart-allarmas take approximately good results..
Why does not work the k-e model?? Must i look and other parameters for work the k-e model???
Please, help me someone....
Old   January 4, 2009, 22:47
uabdillah
I have trouble with my study about flow arround type D cylinder with cutting angle 65 degree with Re=53000. this study using fluent 6.2, i think my meshing is good but still cannot reach intensity 0.2 and length scale 0.01. I hope you can to solve my problem
Thread Tools
Trackbacks are On
turbulent models... chillaks Main CFD Forum 1 December 23, 2005 04:07
How to active the turbulent models w0er FLUENT 12 May 18, 2005 12:11
turbulent models of flow Muhammad zubair Main CFD Forum 0 June 11, 2004 05:26
Different turbulent models! Raintung FLUENT 0 March 24, 2003 21:07
Laminar vs. Turbulent Models Dahvid Brown FLUENT 3 October 23, 2000 02:36
