Error with UDF
Old   January 3, 2009, 15:39
Default Error with UDF
Mustafa Ayad
Dear All I write the a UDF of angular velosity of Gear Pump in "C" Lang. but when try to load the file xxxx.c in fluent the following error ocure please help me for that,,, Regards:
Opening library "libudf"...
Error: open_udf_library: The system cannot find the file specified.
Error Object: ()
Deleted old libudf\ntx86\2ddp\libudf.dll
(system "copy C:\Fluent.Inc\fluent6.3.26\src\makefile_nt.udf libudf\ntx86\2ddp\makefile")
1 file(s) copied.
(chdir "libudf")()
(chdir "ntx86\2ddp")()
'nmake' is not recognized as an internal or external command,
operable program or batch file.
Done.
"c:/users/mohammed_laptop/desktop/gear 3"
Error Object: ()
Old   January 4, 2009, 16:10
Default Re: Error with UDF
sk
Hai,
Please try to open fluent from Visual Basic command prompt. and Then try to compile your udf.
Hopefully it will work.
best wishes. Sk.
Old   January 5, 2009, 01:39
Mustafa Ayad
Thank you But how can i open fluent from Visual Basic command prompt. Regards.
strange fluent error: Primitive Error at Node 0 Jean-Baptiste FLUENT 8 June 14, 2022 11:11
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 04:35
"Error: Floating point error: invalid number" MI Kim FLUENT 2 January 4, 2007 10:00
Fatal error error writing to tmp No space left on device maka OpenFOAM Installation 2 April 3, 2006 08:48
Error: Floating point error: invalid number Bob FLUENT 3 June 3, 2005 18:11
