January 3, 2009, 16:39 |
Error with UDF
Dear All I write the a UDF of angular velosity of Gear Pump in "C" Lang. but when try to load the file xxxx.c in fluent the following error ocure please help me for that,,, Regards:
Opening library "libudf"... Error: open_udf_library: The system cannot find the file specified. Error Object: () Deleted old libudf\ntx86\2ddp\libudf.dll The system cannot find the file specified. The system cannot find the file specified. (system "copy C:\Fluent.Inc\fluent6.3.26\src\makefile_nt.udf libudf\ntx86\2ddp\makefile") 1 file(s) copied. (chdir "libudf")() (chdir "ntx86\2ddp")() 'nmake' is not recognized as an internal or external command, operable program or batch file. 'nmake' is not recognized as an internal or external command, operable program or batch file. Done. "c:/users/mohammed_laptop/desktop/gear 3" Opening library "libudf"... Error: open_udf_library: The system cannot find the file specified. Error Object: () |
January 4, 2009, 17:10 |
Re: Error with UDF
Hai,
Please try to open fluent from Visual Basic command prompt. and Then try to compile your udf. Hopefully it will work. best wishes. Sk. |
January 5, 2009, 02:39 |
Re: Error with UDF
Thank you But how can i open fluent from Visual Basic command prompt. Regards.
Display Modes | |
strange fluent error: Primitive Error at Node 0 | Jean-Baptiste | FLUENT | 8 | June 14, 2022 12:11 |
error in COMSOL:'ERROR:6164 Duplicate Variable' | bhushas | COMSOL | 1 | May 30, 2008 05:35 |
"Error: Floating point error: invalid number" | MI Kim | FLUENT | 2 | January 4, 2007 11:00 |
Fatal error error writing to tmp No space left on device | maka | OpenFOAM Installation | 2 | April 3, 2006 09:48 |
Error: Floating point error: invalid number | Bob | FLUENT | 3 | June 3, 2005 19:11 |
